Compiling the source code [for ArcGIS Viewer for Flex] requires Adobe Flex 4.1 or above. This is to support Arabic and other right-to-left locales. Note that the API itself still works with 4.0, 4.1 as well as 4.5.
In version 2.4 of the Viewer, Adobe Flex 4.1 SDK is the minimum SDK version to compile with.
Azizul, Yes you need to download the 4.1 SDK and extract it to your Flash Builder SDK directory. If you need help with that just Google adding a flex sdk.
I am working for Bangladesh. That is why the online tiles mapping is not enough for me. ... I also have to change the data for Bangladesh.
Azizul, To publish your own data you need ArcGIS Server installed and to become familiar with publishing map services using Server.
Another alternative might be to use OpenStreetMap. Have you looked at OpenStreetMap data? It's the only pre-created tiles that seem to have detailed data for Bangladesh. Plus, you can add & edit the street data as well (on the openstreetmap website).See http://help.arcgis.com/en/webapps/flexviewer/live/index.html?config=apps/config-css-cobalt.xml&extent=49932600,2794110,49944800,2801470&scale=500000
Thank you for introducing me with this OpenStreetMap Service. Is there any rest end point url for OpenStreetMap Service?
But if you already have an ArcGIS Server (9.3 or later) set up, then I'd focus on making that work with your Flex Viewer.
Azizul, Your not the first one to miss these sections of the documentation:From the What's New in 2.4 Viewer (under "General Changes"):It's also mentioned briefly in the "Upgrading your viewer Code":as posted by Bjorn in this threadhttp://forums.arcgis.com/threads/35876-ArcGIS-API-for-Flex-2.4-just-released-%29?p=121408&viewfull=1#post121408
Lefteris, Still separate download as it has more to do with your IDE environment than with esri.
