arcpy.CopyFeatures_management(ptList, r"pointTemp.shp")
# -*- coding: cp1252 -*- # Import modules import arcpy, arcgisscripting, json try: #Workspace #arcpy.env.workspace = r"C:\temp\\" gp = arcgisscripting.create() # ENV Settings arcpy.env.overwriteOutput = 1 # Local variables i = 0 value = 0 ptList = [] rowNumberList = [] pt = arcpy.Point() #String input: input = arcpy.GetParameterAsText(0) #JSON array to Python dictionary data = json.loads(input) for entries in data['points']: rowNumberList.append(data['points']['rowNumber']) pt.X = data['points']['longitude'] pt.Y = data['points']['latitude'] ptList.append(arcpy.PointGeometry(pt)) i += 1 # Create the Shape arcpy.CopyFeatures_management(ptList, r"pointTemp.shp") # Add the filed 'rowNumber' arcpy.AddField_management(r"pointTemp.shp", "rowNumber", "SHORT") # Fill the field 'rowNumber' cur = gp.UpdateCursor(r"pointTemp.shp") row = cur.Next() while row: row.rowNumber = rowNumberList[value] cur.UpdateRow(row) row = cur.Next() value += 1 del cur # Spatial Join arcpy.SpatialJoin_analysis(r"pointTemp.shp",r"C:\arcgisserver\directories\arcgissystem\arcgisinput\cresta\lowres_deutschland.MapServer\extracted\v101\cresta.gdb\Cresta_Low_Res",r"join_result.shp") # FeatureClass / Shapefile, fc = r"join_result.shp" # Fields that should be returned by the cursor field = ["CRESTA_ID"] # Loop through the attribute table with a cursor with arcpy.da.SearchCursor(fc, field) as cursor: for row in cursor: print str(row[0]) arcpy.SetParameterAsText(1, "Eintrag: " + str(row[0])) except Exception, e: arcpy.SetParameterAsText(2, e)
