The file instantly showed up in ArcMap. I restarted ArcCatalog in order to see it but could not change the field data.
Alas, I spoke too soon. When I converted to a shapefile, the properties no longer allow me to add fields (as I would do with any other shapefile). Is it now possible to transfer data between shapefiles?
My original file is in layer form. Can I still add fields from there?
I created a layer file with multiple lines, and I need to create new fields for those lines. I decided to create a new shapefile with the necessary fields. How do I transfer the data from my layer file into the new shapefile? There are 500-1,000 lines in the layer file so recreating the entire file would be excruciatingly tedious.
