No need to set z-index for button here. What makes you want to set z-index? In addition, just learnt today that z-index only works for positioned elements. Please refer to http://coding.smashingmagazine.com/2009/09/15/the-z-index-css-property-a-comprehensive-look/.<button id="locate" data-dojo-type="dijit/form/Button">Locate</button>I can display the button without any problem. See http://jsfiddle.net/4Dm7y/.
Can you post the portion of your html? Normally, buttons should resize themselves automatically unless you specifically set their width and height.
z-index is very tricky. Button's z-index only works within the scope of its container, which is div.floating-layerMenu in your case. Is div.floating-layerMenu visible?
data-dojo-props is used to set the properties for dijit/form/Button, not for style settings. Use style to set css rules.Try:<button id="locate" data-dojo-type="dijit/form/Button" style="z-index: 900">Locate</button>
