Hi
Can I customize the Coordinate Conversion Widget to display only BASEMAP & XY Coordinates and remove the rest from the default conversion options in 4.17
cadgis,
Just add this css rule:
<SPAN class="selector token">.esri-coordinate-conversion__select-row option[value="dd"], [value="ddm"],[value="dms"],[value="mgrs"],[value="usng"] ,[value="utm"]</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="property token">display</SPAN><SPAN class="punctuation token">:</SPAN> none<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
How would you go about this if you were also removing XY? As I understand it, Display: None will not remove the element from the DOM, and so it will render at the first "selected" in the slot, and then only be removed when the user makes a selection.
