Seems Arcade doesn't yet have a math function, like, say: Mod(value, modulo) -> Number
Anyone have a creative function for calculating one using the existing math functions?
Thanks!
User error. Arcade doesn't need a Mod() function. It already has a "%" Modulus operator.
Hi Jim Barry ,
Nice to see you are doing some Arcade! Normally there are several ways that lead to Rome. Here is an example to play around with.
<SPAN class="keyword token">var</SPAN> amount <SPAN class="operator token">=</SPAN> <SPAN class="number token">199.99</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> values <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN><SPAN class="string token">"Penny"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.01</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Nickel"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.05</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Dime"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Quarter"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0.25</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"One Dollar"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Five Dollars"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Ten Dollars"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Twenty Dollars"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">20</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Fifty Dollars"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">50</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"One Hundred Dollars"</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> currencies <SPAN class="operator token">=</SPAN> <SPAN class="token function">Reverse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"Penny"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Nickel"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Dime"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Quarter"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"One Dollar"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Five Dollars"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Ten Dollars"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Twenty Dollars"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Fifty Dollars"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"One Hundred Dollars"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> result <SPAN class="operator token">=</SPAN> <SPAN class="string token">"Pay $ "</SPAN> <SPAN class="operator token">+</SPAN> amount <SPAN class="operator token">+</SPAN> <SPAN class="string token">":"</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="keyword token">in</SPAN> currencies<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> value <SPAN class="operator token">=</SPAN> values<SPAN class="punctuation token">[</SPAN>currencies<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">==</SPAN> <SPAN class="token function">Count</SPAN><SPAN class="punctuation token">(</SPAN>currencies<SPAN class="punctuation token">)</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> coinsbills <SPAN class="operator token">=</SPAN> <SPAN class="token function">Round</SPAN><SPAN class="punctuation token">(</SPAN>amount <SPAN class="operator token">/</SPAN> value<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> coinsbills <SPAN class="operator token">=</SPAN> <SPAN class="token function">Floor</SPAN><SPAN class="punctuation token">(</SPAN>amount <SPAN class="operator token">/</SPAN> value<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>coinsbills <SPAN class="operator token">></SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> result <SPAN class="operator token">+</SPAN><SPAN class="operator token">=</SPAN> TextFormatting<SPAN class="punctuation token">.</SPAN>NewLine <SPAN class="operator token">+</SPAN> <SPAN class="string token">" "</SPAN> <SPAN class="operator token">+</SPAN> coinsbills <SPAN class="operator token">+</SPAN> <SPAN class="string token">" "</SPAN> <SPAN class="operator token">+</SPAN> currencies<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// amount -= coinsbills * value;</SPAN> amount <SPAN class="operator token">=</SPAN> <SPAN class="token function">Round</SPAN><SPAN class="punctuation token">(</SPAN>amount<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">%</SPAN> <SPAN class="punctuation token">(</SPAN>coinsbills <SPAN class="operator token">*</SPAN> value<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">return</SPAN> result<SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
This will return:
Pay $ 199.99: 1 One Hundred Dollars 1 Fifty Dollars 2 Twenty Dollars 1 Five Dollars 4 One Dollar 3 Quarter 2 Dime 4 Penny<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
As you can see on line 21 and 22 you can use either way.
Edit: changed code to resolve a nasty error due to rounding.
Hi Xander!!
Oh, that's neat. Thanks for the script. Nice use of modulus, and creative example of doing the same without it.
Here's a slide deck I used, giving an Intro to Arcade 30-min session at the Mid-Atlantic User Conference a few weeks ago: Arcade: an Introduction - Esri MUC 2019
Hi jbarry-esristaff ,
Thanks for sharing the slide deck. Very cool!
