<?xml version="1.0" ?> <configuration> <initialview>text</initialview> <layers> <layer> <name>Clay County Road</name> <url>http://server/server/rest/services/Layers/MapServer/102</url> <expression>upper(FullName) LIKE upper('%[value]%')</expression> <textsearchlabel>Search by Street Name [ Example: Old Jennings Rd or Jennings ]</textsearchlabel> <titlefield>FullName</titlefield> <linkfield></linkfield> <fields all="false"> <field name="FullName" alias="Street" /> </fields> <orderbyfields>FullName ASC</orderbyfields> </layer> <layer> <name>Bradford County Road</name> <url>http://server/server/rest/services/Layers/MapServer/103</url> <expression>upper(NAME) LIKE upper('%[value]%')</expression> <textsearchlabel>Search by Street Name [ Example: State Road 100 or 100 ] </textsearchlabel> <titlefield>NAME</titlefield> <linkfield></linkfield> <fields all="false"> <field name="NAME" alias="Street" /> </fields> <orderbyfields>NAME ASC</orderbyfields> </layer> </layers> <zoomscale>10000</zoomscale> <symbols> <simplelinesymbol width="4" /> </symbols> </configuration> <!-- See Search widget documentation at http://links.esri.com/searchwidget -->
private function createSearchResults(featureSet:FeatureSet, queryFields:XMLList):ArrayCollection { var result:ArrayCollection = new ArrayCollection(); var layerDetails:LayerDetails = queryLayer.layerDetails; if (!queryTitleField) { queryTitleField = featureSet.displayFieldName; } for each (var graphic:Graphic in featureSet.features) { var resultAttributes:ResultAttributes = ResultAttributes.toResultAttributes(queryFields, graphic, featureSet, queryLayer, layerDetails, widgetTitle, queryTitleField, queryLinkField, queryLinkAlias); setDefaultGraphicSymbol(graphic); var searchResult:ResultItem = new ResultItem(graphic, resultAttributes); result.addItem(searchResult); var infoWindowRenderer:ClassFactory = new ClassFactory(PopUpRenderer); infoWindowRenderer.properties = { popUpInfo: configurePopUpInfo(resultAttributes)}; graphic.infoWindowRenderer = infoWindowRenderer; } resultFeatureLayer.outFields = queryLayer.outFields; resultFeatureLayer.visible = true; resultFeatureLayer.featureCollection = new FeatureCollection(featureSet, layerDetails); switch (featureSet.geometryType) { case Geometry.MAPPOINT: { resultFeatureLayer.renderer = new SimpleRenderer(resultMarkerSymbol); break; } case Geometry.POLYLINE: { resultFeatureLayer.renderer = new SimpleRenderer(resultLineSymbol); break; } case Geometry.POLYGON: { resultFeatureLayer.renderer = new SimpleRenderer(resultFillSymbol); break; } } return result; } private function setDefaultGraphicSymbol(graphic:Graphic):void { switch (graphic.geometry.type) { case Geometry.MAPPOINT: { graphic.symbol = resultMarkerSymbol; break; } case Geometry.POLYLINE: { graphic.symbol = resultLineSymbol; break; } case Geometry.POLYGON: { graphic.symbol = resultFillSymbol; break; } } }
Daniel, Wow, I had not noticed that... Well If you are using the source code then there is a simple fix for this:Make the changes in red in the SearchWidget.mxml private function createSearchResults(featureSet:FeatureSet, queryFields:XMLList):ArrayCollection { var result:ArrayCollection = new ArrayCollection(); var layerDetails:LayerDetails = queryLayer.layerDetails; if (!queryTitleField) { queryTitleField = featureSet.displayFieldName; } for each (var graphic:Graphic in featureSet.features) { var resultAttributes:ResultAttributes = ResultAttributes.toResultAttributes(queryFields, graphic, featureSet, queryLayer, layerDetails, widgetTitle, queryTitleField, queryLinkField, queryLinkAlias); setDefaultGraphicSymbol(graphic); var searchResult:ResultItem = new ResultItem(graphic, resultAttributes); result.addItem(searchResult); var infoWindowRenderer:ClassFactory = new ClassFactory(PopUpRenderer); infoWindowRenderer.properties = { popUpInfo: configurePopUpInfo(resultAttributes)}; graphic.infoWindowRenderer = infoWindowRenderer; } resultFeatureLayer.outFields = queryLayer.outFields; resultFeatureLayer.visible = true; resultFeatureLayer.featureCollection = new FeatureCollection(featureSet, layerDetails); switch (featureSet.geometryType) { case Geometry.MAPPOINT: { resultFeatureLayer.renderer = new SimpleRenderer(resultMarkerSymbol); break; } case Geometry.POLYLINE: { resultFeatureLayer.renderer = new SimpleRenderer(resultLineSymbol); break; } case Geometry.POLYGON: { resultFeatureLayer.renderer = new SimpleRenderer(resultFillSymbol); break; } } return result; } private function setDefaultGraphicSymbol(graphic:Graphic):void { switch (graphic.geometry.type) { case Geometry.MAPPOINT: { graphic.symbol = resultMarkerSymbol; break; } case Geometry.POLYLINE: { graphic.symbol = resultLineSymbol; break; } case Geometry.POLYGON: { graphic.symbol = resultFillSymbol; break; } } }
<symbols> <simplefillsymbol color="0x00ffff" alpha="0.5"> <outline color="0xff0000" alpha="0.8" width="2" /> </simplefillsymbol> <picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0xff0000" alpha="0.8" width="2" /> </symbols>
Daniel, Whether the layer is 100% transparent or not even added as an operational layer to the map the search should still add results to the map... Try adding all the default symbols:<symbols> <simplefillsymbol color="0x00ffff" alpha="0.5"> <outline color="0xff0000" alpha="0.8" width="2" /> </simplefillsymbol> <picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> <simplelinesymbol color="0xff0000" alpha="0.8" width="2" /> </symbols>
Daniel, I have no problem at all getting a polyline layer to show results upon searching that layer. See attached image.[ATTACH=CONFIG]26831[/ATTACH]
