I have some searches of feature layers that are not working in the web application. They work fine in the web map viewer, however.
Hi Lisa,
Can you provide more detail? For example:
1. What application are you using? (i.e. Web AppBuilder, Basic Viewer, etc)
2. What type of service are you using? (i.e. ArcGIS Online Hosted Feature Service, ArcGIS Server Map Service)
3. What is occurring when you try to search for the feature?
4. Are you able to provide a URL to the application?
Hi Jake.
1. I'm using Web Appbuilder
2. Services are ArcGIS Server Services
3. I get response that "no results were found for 'x'"
4. These are secure services so I'm afraid the URL won't help
Thanks for your response. I have other applications that were built with web AppBuilder that are working. In some of the applications, some searches still work whereas others do not.
If you press F12 on your keyboard this will open your web browser's Console. When you perform the search, are there any error's reported there?
None that I see but I may not be looking in right spot.
1. Web appbuilder
2. ArcGIS Server service
3. Search is working and returns list to choose from but when you select the one you want, it doesn't zoom to it or trigger a pop up.
4. The service is secure so I can't share. I suspect there is something in this particular mxd that is causing the issue. There are a lot of field aliases and definition queries.
Lisa
Sent from my iPhone
