Did you change the UNICODE_STRING in the dbtune.sde file or in SDE.DBTUNE?(Or both, by running 'sdedbtune -o import'?)- V
An 'sdeimport' *also* maps SE_STRING_TYPE to NVARCHAR2? That's bizarre.How is your character set defined? As SYSTEM:SELECT value$ FROM sys.props$ WHERE name = 'NLS_CHARACTERSET'; and/or SELECT * FROM NLS_DATABASE_PARAMETERS;Did you change the UNICODE_STRING in the dbtune.sde file or in SDE.DBTUNE?(Or both, by running 'sdedbtune -o import'?)- V
