Are you using a GG03 or GG02 plus with the CS25 unit or just the SiRF chipset in the CS25 unit? If using the GG03 or GG02 plus, then it is possible through a product called Zeno Connect. Zeno Connect would be installed on the laptop, then a bluetooth or cabled connection to your GG03/GG02 plus unit.
Are you using the GG03 or GG02 plus? If not, then Zeno Connect will not be needed. If you are only using the internal SiRF GPS chipset, you can set your COM settings accordingly. If you are using the GG03 or GG02 plus, then yes, Zeno Connect will handle the configuration of the GG0X unit as well as configuring the NMEA sentences for use in ArcPad.
Then do I need to purchase hardware (GG03) and software (Zeno Connect) just to get my GPS device (leica CS25) connected with my laptop/tablet machine?
Depending on the age of the unit, there is either a MiniGPS or U-Center application installed that manages the NMEA data. You may be able to utilize it to relay the data to a bluetooth port or the serial port, but it is unlikely.
The internal GPS of the CS25 unit is on COM 3, with a baud rate of 38400. So if your software was on the CS25 unit, you'd make the appropriate COM port and baud rate settings.
Another question is if you are aware of the accuracy achievable with and without an external GPS antenna like the GG03, and whether that plays a role in your decision, or need, for extra hardware.Looking at the specs for the Leica-CS25, it seems the CS25 will only achieve a 2-5 meter accuracy on its internal GPS antenna (and that is corrected by an external augmentation signal as WAAS in the US or EGNOS in Europe). If not using augmentation or DGPS, it will be worse. If you need RTK/DGPS "survey" accuracy down to the cm level, it seems you either need to have the compact antenna that is provided as part of the Leica CS25 GNSS package (which will give you 10-20 cm accuracy when referenced to a base station, and is directly pluggable in the CS25 computer), or a bigger fully separate "pole type" GG03 L2 receiver, which should give you up to cm level accuracy when corrected by known references.It probably is not of any direct help since the GPS unit is not in the laptop, but in the separate CS25, but it seems ArcGIS / ArcPad 10.2 has enhancements in this respect via new customization options using the Windows Locations API, and the new "Location Sensor" option in ArcPad based on this:What is a location sensor?What's New in ArcPad 10.2 (Video)And see this for other ideas to directly tap into NMEA data (for those with electronics skills...):GPS Test 1 - Reading NMEA Data using an Arduinohttp://www.arduino.cc/NMEA dataIt probably is easier to install ArcPad (Studio) on the the CS25, and do testing using live GPS there.
I couldn�??t figure out:1. The accuracy of the measurement2. How to connect it with reference station to improve the accuracy
If I look at the product folder for the GG03 here, it says that for the "integrated real time" SBAS correction (Satellite Based Augmentation System), your accuracy is about <0.9 meter. With correction against a known, surveyed, reference station as in DGNSS (Differential Global Navigation Satellite System), also called DGPS, you should achieve around 0.4 meter, depending on the distance between your reference point and the location where you are surveying. Lastly, with RTK, you should be able to get down to less than a decimetre, up to 1 cm.So, without tying yourself to any ground based reference point as in DGNSS or RTK mode, you will have about 1 meter accuracy at best. Please note that for both DGNSS/DGPS and RTK, you need to be able to contact a known reference station. A lot of countries have government or commercially maintained reference networks for this, with fixed GPS receiver base stations broadcasting their positions and corrections (CORS - Continously Operated Reference Station). This may be a paid service in your area.I don't know if Palestine has its own CORS network?, but these articles might be interesting for you:The Permanent GNSS Network and its RTK Application in Israelhttp://www.fig.net/commission5/wg52/ts01c_salmon_3248.pdfPermanent GPS Network-based Measurement Practice in Israelhttp://www.mapi.gov.il/UsefulInfo/MapiPublications/FIG2009_forrai_3496.pdfAs Brett says, some training might be in order...
1. My issue in this thread was to find a way to connect my GPS system with other tablet\laptop due to that fact that the touch screen of the Lieca CS25 is really irresponsive and made my life hard when doing few click. I wanted to replace it with other tablet (like Dell �??latitude 10 with windows 😎 so that I can enjoy doing my survey tasks. By the way, is the tablet of the Lieca CS25 has a particular chipset that receives signals even without the GG03 Antenna?
2. Then I moved to the accuracy issue. I got that the subscription is like $700/year (in Palestine) for the correction. Technically, how to check the current system on my Lieca CS25 machine (internet connection + GG03 Antenna): DGNSS\DGPS\RTK? And then is there a command that shows the level of accuracy that can be reached?
Did you actually manage to create a Bluetooth connection between your laptop and the GG03 antenna using the Zeno Field or Connect software on your laptop? The only other option to connect the GG03 to your laptop seems a dedicated type of cable, with a Lemo connector on one side (that connects to the GGO3, see these Leica specs for the GGO3), and a serial RS232 on the other side, see this link:http://www.surveyequipment.com/accessories/cables/leica-gev162-2.8m-gps-data-transfer-cable-lemoserial#.Un9K3OKp7kwSince most modern ultrathin tablets / laptops tend to lack this rather bulky and old type serial port, you will probably need a converter from RS232 to USB too, to be able to connect it to your laptop (The Leica CS25 is fitted with RS232 port according to the specs), like for example this one:http://www.startech.com/Cards-Adapters/Serial-Cards-Adapters/USB-RS232-DB9-Serial-Adapter-Cable~ICUSB232
Many thanks Marco,I have already sent an e-mail to the re-seller of Leica �??Geosystem inquiring the best way to get the GG03 connected to other tablet (like Dell Latitude 10) that is fast and very responsive.We have licensed ArcPad and wanted to know which other software\hardware components are required to establish such connection (GG03 and tablet)I�??m waiting their answer.
Good, but looking at the specs of the Dell Latitude 10, it clearly says it supports Bluetooth, which is also the way to connect to the GG03. So I repeat my question: did you manage to create a Bluetooth connection from one of your laptops or tablets supporting it, to the GG03 GPS receiver?I don't think you will be needing anything extra, besides what you already have. Except maybe it might be better to switch to Leica Zeno Field instead of ArcPad. Leica Zeno Field seems a modified ArcPad designed for easy Leica GPS access, see here:http://www.leica-geosystems.com/en/Leica-Zeno-Field-Office_79643.htm*** EDIT *** I forgot to read back the older posts, but you already seem to have Zeno Field, considering the screenshot you posted. So if you manage to create that Bluetooth connection to the GG03 from your preferred device running Zeno Field, I guess you are done.
What I couldn�??t figure out is the way the reference stations recognizes our CS25 tablet\GG03 Antenna? How our CS25 is detected by the reference base?1. Is the internal GPS in the CS25 tablet is registered? How it is registered? IP address of the CS25 tablet?2. Is the GG03 is registered?
I tried to connect my Dell tablet (latitude 10) with the GG03 but sounds not to work. The Dell tablet recognizes the GG03 Antenna #205964 but required passcode. What does the passcode refer to in this case?
I am not entirely sure what you mean with "registered". Bluetooth as a wireless connection method / protocol has its own way of establishing connections. You may wish to have a look here for example:How To Use Bluetooth On Windows 8Bluetooth on WikipediaThe connection is via Bluetooth. The passcode is a security feature of Bluetooth. Sometimes you only need to confirm an already displayed passcode, and at other times to type one you know from configuring it on the other device or documentation of the device, as in your case.However, I can't tell whether the passcode is fully configurable or fixed for each individual GG03 antenna. Brett probably can tell.If I needed to guess, a candidate to try would be the equipment number (Equip. No.) or, in a bad case of recycling vital info already displayed and send out as part of the Bluetooth device name in Windows, the same Serial Number (S. No.) as marked on the type plate of the GG03.
If a bluetooth passkey is required by the driver, then it is "0000" (remove the quotations). As far as network corrections are concerned, the requirements depend on the provider. If it is NTRIP, then they would provide the IP address and port number as well as a username and password. NTRIP also requires you to send your current location via the GGA NMEA string, so be sure to toggle on the "Use NTRIP with Server" section when entering your Real-time profile. If it is a DirectIP connection, then all that is needed is the IP address and port number. All this information comes directly from the provider.You will need to make certain you have an active internet connection. The CS25 has an internal GSM modem, so you can insert a SIM card with a data plan associated with it to access the internet. Depending on how new the CS25 is, the GSM modem is either managed by OneClick Internet or AirCard Watcher software. You can also use an external WiFi modem as well.All corrections are provided in real-time. If you provider is sending dual-frequency RTK corrections via NTRIP you will select a mountpoint from the source table. The network I use, I select RTCM3_Max, RTCM3_IMAX or RTCM3_NEAR. This provides me with centimeter level accuracy with the same configuration you are using.
