Trying to add a webmap but even in the sandbox I get
Fetch API cannot load https://tileservice.charts.noaa.gov/tiles/wmts/1.0.0/WMTSCapabilities.xml due to access control checks.https://tileservice.charts.noaa.gov/tiles/wmts/1.0.0/WMTSCapabilities.xml
Origin xyz is not allowed by Access-Control-Allow-Origin
var webmap = new WebMap({ portalItem: { id: "ec16ffd3c25b4e3d8af9c1bf9a14af08" } });
Any suggestions?
It looks like the 4x API is a bit more strict with cors and ssl than the 3x version (which is why I think it displays in the 3x based AGO Map Viewer). If you add a proxy to the mix, the wmts webmap displays fine.
Resources:
CORS with the API | ArcGIS API for JavaScript 4.14
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
https://codepen.io/noash/pen/BayWZKv (codepen does not run, but if you supply a link to your proxy and run locally, it will work)
