First time dealing with cursor. I have lines intersecting polygons, I want to get a table with all attributes of the lines, add a field and calculate the field as the name of the polygon. I was able to get a table for each polygon but I can't get to calculate the field and add the polygon name. How do I do? here is my code:import arcpy
arcpy.env.workspace = 'C:\\Users\\a391665\\Documents\\ArcGIS\\Default.gdb'
ws = 'C:\\Users\\a391665\\Documents\\ArcGIS\\Default.gdb'
Comuni = 'C:\\Users\\a391665\\Documents\\ArcGIS\\Sardegna3.gdb\\Comuni'
Linee = 'C:\\Users\\a391665\\Documents\\ArcGIS\\Sardegna3.gdb\\Linee'
rows = arcpy.SearchCursor(Comuni)
for row in rows:
print row.NOME
feat = row.Shape
arcpy.SelectLayerByLocation_management("Linee", "INTERSECT", feat, selection_type="NEW_SELECTION");
out_feature_class = arcpy.ValidateTableName("Linee_Clip_" + row.NOME);
table = arcpy.TableToTable_conversion("Linee", ws, out_feature_class);
arcpy.AddField_management(out_feature_class, 'Clip', 'TEXT', '', '', '60');
expression = arcpy.ValidateTableName(row.NOME);
arcpy.CalculateField_management(table, "Clip", expression);here is the error I get:Empty value for ObjectID = 1 The calculated value is invalid for the row with ObjectID = 1. For example, the calculated value may be too large for the field or you may be trying to add a string to a number field. This row will not be updated.
