I'm not sure if you simply want to update symbol template to include an arrow or if you wanted an arrow shape.
For custom symbols, you can try this SDK sample: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers or symbol gallery: ArcGIS API for Silverlight - Symbol Gallery. Basically, you will need a LineSymbol and define a Control Template that includes an Arrow Shape.
If you want an arrow shape, you can try this SDK sample: ArcGIS API for Silverlight - Interactive Samples | ArcGIS for Developers click on the button with "Add an arrow" tooltip and then mouse down + drag + up to create this shape.
By default, this creates a Polygon but you can subscribe to DrawComplete and convert to Polyline.
void Button_Click(object sender, RoutedEventArgs e)
var draw = new Draw(MyMap);
draw.DrawMode = DrawMode.Arrow;
draw.DrawComplete += draw_DrawComplete;
draw.IsEnabled = true;
void draw_DrawComplete(object sender, DrawEventArgs e)
((Draw)sender).DrawComplete -= draw_DrawComplete;
var polygon = (Polygon)e.Geometry;
var polyline = new Polyline() { SpatialReference = polygon.SpatialReference };
foreach (var r in polygon.Rings)
polyline.Paths.Add(r);
var layer = MyMap.Layers["MyLayer"] as GraphicsLayer;
layer.Graphics.Add(new Graphic() { Geometry = polyline, Symbol = new SimpleLineSymbol() });
Pretty sure that I saw the new .net SDK come with an Arrow type?
You could consider extending the Draw class - see this example: Custom Draw Tool
Cheers
Mike
