Hi All,
I tried running the Copy Parcels tool just to see how it works and got the following error:
Has anyone else seen this?
Mike
Hi Mike,
There are 2 issues I see:
1. You are trying to copy a parcel fabric from a feature dataset to the SAME feature dataset. We only allow one parcel fabric per feature dataset.
2. The name of the input parcel fabric is the same as the output in the SAME geodatabase.
Recommendation:
The geoprocessing Copy Parcels is best used as an exchange mechanism and replaces the old cadastral XML format. So you can create a new File GDB and export the (selected) parcels into it without having to rename it.
