I'm not sure that any of those errors are related to your issue, either. That being said, I don't know enough about the timeline of when these errors occurred and when you attempted the copy/paste where it failed thereafter. If you're using direct connect, the sdedc_Oracle.log file should be somewhere on your machine. Are you using direct connect or the ArcSDE application service to connect to your enterprise geodatabase? It would also be good to get the exact version of your RDBMS and ArcGIS/ArcSDE software before going any further.
You're using direct connect to establish the connection to your enterprise geodatabase, right? We need to capture the Oracle error code before knowing what the issue might be according to your database. What does the following log file say?C:\Users\<your_user_ID>\AppData\Local\Temp\sdedc_Oracle.logWhat do your Oracle database Alert log files show?Typically located at C:\oracle\diag\rdbms\<db_name>\<db_name>\alert\log.xmlTypically located at C:\oracle\diag\rdbms\<db_name>\<db_name>\trace\alert_<db_name>.logNote: Replace <db_name> with the name of your Oracle database SID.
Copying and pasting a FGDB into SDE seems like a lot to ask. My suggestion is to import your feature classes from the FGDB into SDE with the import multiple feature classes utility.
Hello -I'm trying to copy/paste a File Geodatabase into an Oracle SDE Instance running in Windows 7. There are 61 classes in the FGDB. When it hits about the 6th class I get the error:Failed to paste <dataset>Underlying DBMS errorFrom there I'm trying to find out what kind of error was encountered. I've looked in the Windows Event Viewer but can't find anything there. Is there another location where I could find more details about the error?Thanks,Ed
