function showResults(results) { //This function works with an array of FindResult that the task returns map.graphics.clear(); var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([98,194,204]), 2), new dojo.Color([98,194,204,0.5])); //Create Extent to use for view an area containing all the search results var SearchAreaExtent; //create array of attributes var items = dojo.map(results,function(result){ var graphic = result.feature; graphic.setSymbol(symbol); map.graphics.add(graphic); //Add Extent to Search Area Extent if (SearchAreaExtent) SearchAreaExtent = SearchAreaExtent.union(graphic.geometry.getExtent()); else SearchAreaExtent = graphic.geometry.getExtent(); return result.feature.attributes; });
dojo.style(dojo.byId("map"), "height", "75%");
esri.hide(datagrid); dojo.style(dojo.byId("map"), "height", "93%");
esri.show(datagrid); dojo.style(dojo.byId("map"), "height", "77%");
function collapseList() { dojo.byId("rightPane").style.display = 'none'; dojo.style(dojo.byId("mapDiv"), "width", "100%"); dijit.byId("mapDiv").resize(); map.resize(); map.reposition();
esri.hide(MyContentPane);
esri.show(MyContentPane);
map.resize(map)
You may want to have the datagrid inside a FloatingPane,http://dojotoolkit.org/reference-guide/1.7/dojox/layout/FloatingPane.htmlAnd you can always make any element hidden/visible,Ex: dojo.byId('grid').style.visibility = 'visible';
