Again, the same thing I have to consistent to change the Elevation set to "On the ground" and is there a way around to set it permanent ?
Using ArcGIS Pro 3.5.6
In ArcGIS Pro 3.5.6, “On the ground” is a per-layer setting (saved with the map/scene in your project). There isn’t a single global option to force all new layers to always be “On the ground.” It appears the only "permanent default" one can set in the default ground elevation surface used by new scenes →settings→options→Map and Scene→Ground Elevation Surface.
