Hello everyone,
I'm standing up an isolated environment for a client's ArcGIS Enterprise upgrade (10.9.1 → 11.5), built fresh on AWS rather than upgraded in place. The goal is to validate workflows before cutting over to production.
The new environment will run at https://gistest.company.com/portal so I can test publishing, Experience Builder apps, traditional versioning with two-way replication, and a set of Esri hardening and IIS security changes. Once testing is complete, I need to point the URL back to https://gis.company.com/portal.
The blocker: a host-file edit won't work here since these workflows need to hit the real internal ArcGIS Enterprise environment. I also can't update the license file on my.esri to reflect the test URL — if I delete the existing portal license and generate a new one for gistest.company.com, I then can't reach the portal to apply it, since the portal URL and license URL are out of sync.
I found Esri's doc on updating the organization URL (link below), but it's light on detail, and I'm not sure whether following it risks breaking federation with the rest of the site (Server, hosting, etc.):
Update the organization URL — Portal for ArcGIS | ArcGIS Enterprise 11.5 docs
https://enterprise.arcgis.com/en/portal/11.5/administer/windows/update-the-organization-url.htm
Has anyone gone through this URL swap (test → prod naming) on 11.5 without breaking federation, or found a cleaner way to license a temporary environment for this kind of side-by-side testing?
Lavanya
