Hi everyone,
I've run into a strange issue while printing map layouts from ArcGIS Pro.
Everything looks great in the Layout view, but after printing, some of the labels appear slightly blurry, colors look less vibrant than expected, and thin grid lines aren't as sharp as they appear on screen. The exported PDF also looks fine, so I'm starting to think the problem might be related to the printer rather than the map itself.
So far I've tried:
- Exporting at 300 DPI and 600 DPI
- Updating the printer driver
- Printing from both the PDF and directly from ArcGIS Pro
- Disabling image compression during export
Before printing more copies, I ran a printer test page to check whether the issue was with the printer's color output or alignment. That actually helped me confirm the printer needed calibration rather than there being a problem with the ArcGIS layout. I used this free online test page tool.
I'm curious how others handle this. Do you have a standard workflow for checking printer calibration before printing maps or large-format layouts? Any tips for getting more consistent print quality from ArcGIS Pro would be appreciated.
Thanks!
