This post made me go back to my code and think about this issue again and I think I've come up with a simple solution that works. I've gotten IsNull to work in the past so I think the problem is actually caused because I'm casting the output path of a PolygonToRaster function to a raster by simply doing polyRaster = Raster(outputPath) - which should work and generally does for casting path strings to Raster objects.If I instead make a raster layer using MakeRasterLayer_management and use that layer name as the input to my subsequent operations (Con in this case), it works without issue.So my code went from this:arcpy.PolygonToRaster_conversion(inPoly,valueField,outputPath,"CELL_CENTER","#",arcpy.env.cellSize)polyRaster = Raster(outputPath)output = Con(IsNull(polyRaster),0,polyRaster) ##Returns 999998: Unexepected Errorto this:arcpy.PolygonToRaster_conversion(inPoly,valueField,outputPath,"CELL_CENTER","#",arcpy.env.cellSize)arcpy.MakeRasterLayer_management(outputPath,"polyRaster")output = Con(IsNull("polyRaster"),0,"polyRaster")So the solution works for me but there must be a bug in the type casting or something...
RuntimeError: ERROR 000732: Input Raster: Dataset d:\Users\MICHAL~1.THI\AppData\Local\Temp\x923a0602_2133_4e68_bd44_b285094f1537y0.afr does not exist or is not supported
