Since upgrading to the 2026 version of monitor (currently on 26.1), we've noticed that Monitor will lose connection to our servers a few times a day.
Each disconnect will last approx 5 mins, before reconnecting without issue.
There is no pattern behind this, it will happen seemingly at random times of day and night.
This appears to be a monitor issue as we have manually checked the network, and each environment at the time when monitor has lost connection, and all appears to be fine.
This will happen on Portal, Enterprise Server, Hosting Server, Image Server, Hosting Server and Web Server, but happens more on Portal and Enterprise Server.
Checking the logs, I can see no reason that this is happening. This is both the Monitor logs, and also the server logs.
Can anyone suggest what may be happening?
Many thanks
Andrew
