I have noticed that when trying to embed a Flourish visualization (using the iframe method), it often cuts the bottom of the iframe off. It doesn't matter what I enter for the height parameter either. Is this a known issue? Can a fix be applied?
Just a standard block inline. Everything displays correctly otherwise.
https://arcg.is/1DHWOC1 - example. This seems to happen more consistently with a viz that is vertically oriented. The viz on Flourish is https://public.flourish.studio/visualisation/29502792/. Adjusted as many of the parameters in the iframe as I could think of, no joy. Also doesn't matter if I use an iframe or not.
> If you open the Flourish visual directly (outside StoryMaps), does it display correctly at full height?
This was right right question to ask, @ShaneONeill_144
@R_C_Miessler -- When I open the embed URL in a separate browser tab, I see the bottom cut off, so this seems to be an issue with the content itself rather than how the StoryMap is displaying the content.
https://flo.uri.sh/visualisation/29502792/embed
This is the URL you see when you click the Embed button and get iframe embed code for this diagram, and its what the content provider redirects to when you embed the diagram using its regular URL (https://public.flourish.studio/visualisation/29502792/).
I would recommend reaching out to the content provider's support channels to see if they can help resolve the issue. Perhaps there is a configuration setting that can be adjusted to make sure the entire diagram is visible?
