esri|PopUpRenderer { skinClass:ClassReference('com.esri.viewer.skins.PopUpRendererSkin'); }
override protected function commitProperties():void { super.commitProperties(); var featureLayer:FeatureLayer = hostComponent.featureLayer; var formattedAttributes:Object = hostComponent.formattedAttributes; var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var popUpInfo:PopUpInfo = hostComponent.popUpInfo; var validMediaInfos:Array = hostComponent.validPopUpMediaInfos; var geometry:Geometry = graphic ? graphic.geometry : null; var layerDetails:LayerDetails = featureLayer ? featureLayer.layerDetails : null; vGroup.removeAllElements(); if (popUpInfo) { if (popUpInfo.title) { titleText.text = StringUtil.substitute(popUpInfo.title, formattedAttributes); if (titleText.text) { vGroup.addElement(titleText); vGroup.addElement(titleLine); } } var htmlText:String; if (popUpInfo.description) { htmlText = StringUtil.substitute(popUpInfo.description, formattedAttributes); if (htmlText) { var descriptionText:Text = new PopUpText(); descriptionText.percentWidth = 100; descriptionText.styleSheet = textStyleSheet; cleanAndSetHtmlText(descriptionText, htmlText); vGroup.addElement(descriptionText); } } else { var descriptionForm:Form; var item:Text=new PopUpText(); for each (var fieldInfo:PopUpFieldInfo in popUpInfo.popUpFieldInfos) { if (fieldInfo.visible) { var formItem:FormItem = new FormItem(); formItem.label = fieldInfo.label || fieldInfo.fieldName; var label:Label; htmlText = formattedAttributes[fieldInfo.fieldName]; if (htmlText) { // convert attribute field values that just contain URLs into links var match:Array = htmlText.match(/^\s*((https?|ftp):\/\/\S+)\s*$/i); if (match && match.length > 0) { label = new Label(); htmlText = '<a href="' + match[1] + '" target="_blank">' + match[1] + "</a>"; } else { label = new PopUpText(); } cleanAndSetHtmlText(label, htmlText); label.selectable = true; label.styleSheet = this.textStyleSheet; label.width = 150; if(label.htmlText.length>1){ item.text=item.text+fieldInfo.label+" "+ label.htmlText.toString()+"\n"; } //formItem.styleName = "formItemStyle"; //formItem.addChild(label); } if (!descriptionForm) { descriptionForm = new Form(); descriptionForm.percentWidth = 100; descriptionForm.horizontalScrollPolicy = ScrollPolicy.OFF; descriptionForm.verticalScrollPolicy = ScrollPolicy.OFF; descriptionForm.styleName = "formStyle"; } //descriptionForm.addChild(formItem); } } vGroup.addElement(item); if (descriptionForm) { vGroup.addElement(descriptionForm); } } if (validMediaInfos && validMediaInfos.length > 0) { vGroup.addElement(mediaBrowser); mediaBrowser.attributes = graphic.attributes; mediaBrowser.formattedAttributes = formattedAttributes; mediaBrowser.popUpFieldInfos = popUpInfo.popUpFieldInfos; mediaBrowser.popUpMediaInfos = validMediaInfos; } if (popUpInfo.showAttachments && graphic && featureLayer && layerDetails && layerDetails.hasAttachments && layerDetails.objectIdField) { vGroup.addElement(attachmentInspector); attachmentInspector.showAttachments(graphic, featureLayer); } if (map && geometry) { //vGroup.addElement(zoomToButton); } } } private function cleanAndSetHtmlText(labelCntrl:Label, htmlText:String):void { if (labelCntrl && htmlText != null) { htmlText = htmlText.replace(/<div/gi, "<br /><div"); // divs are ignored so put br's in front of them htmlText = htmlText.replace(/<div><br ?\/><\/div>/gi, ""); // remove existing <div><br /></div>'s so we don't have too many new lines // add target="_blank" to all anchor tags htmlText = htmlText.replace(/<a.*?href\s*=\s*["']([^"']*).*?>(.*?)<\/a\s*>/gi, '<a href="$1" target="_blank">$2</a>'); labelCntrl.htmlText = htmlText; } } private function zoomToButton_clickHandler(event:MouseEvent):void { var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var geometry:Geometry = graphic.geometry; var extent:Extent = geometry.extent; // returns null for MapPoint or Multipoint's with only one point if (extent) { map.extent = extent; // make sure the whole extent is visible if (!map.extent.contains(extent)) { map.level--; } } else { // code here } } ]]> </fx:Script> <fx:Declarations> <!--- @private --> <mx:Text id="titleText" width="100%" fontSize="18" fontWeight="bold"/> <!--- @private --> <s:Line id="titleLine" width="100%"> <s:stroke> <s:SolidColorStroke id="titleLineSymbol" color="black" weight="1"/> </s:stroke> </s:Line> <!--- @private --> <supportClasses:PopUpMediaBrowser id="mediaBrowser" width="100%" skinClass="com.esri.ags.skins.supportClasses.PopUpMediaBrowserSkin"/> <!--- @private --> <esri:AttachmentInspector id="attachmentInspector" width="100%" addEnabled="false" deleteEnabled="false"/> <!--- @private --> <!-- <mx:LinkButton id="zoomToButton" click="zoomToButton_clickHandler(event)" fontWeight="bold" label="{resourceManager.getString('ESRIMessages', 'zoomLabel')}"/>--> </fx:Declarations> <s:Scroller width="100%" height="100%"> <!--- @private --> <s:VGroup id="vGroup" fontFamily="arial" fontSize="10" fontStyle="normal" fontWeight="normal" paddingBottom="0" paddingLeft="0" paddingRight="0" paddingTop="0" gap="0" verticalAlign="top"> <!-- elements are added in commitProperties() --> </s:VGroup> </s:Scroller> </s:SparkSkin>
I had the same problem but corrected it by modifying the popUpRendererSkin. If you look at the skin you will see it uses forms and formItem, which i think have some kind of default spacing.
