After running the the Create Migration Workspace, the log indicates associations were not found. I validated the relationship class in the map by selecting and retrieving related data. Other associations in the Simple Data Mapping sheet seemed to work. These relationship classes are using GlobalID and appear the same as other relationship classes that did work.
See also the attached for association key configurations. The screen shot is filtered only for these three keys, but other associations are configured in the data mapping sheet.
What else can I do to confirm my configuration is correct or debug the issue?
ArcGIS Pro 3.6.2.59527
udms 3.5
Executing from ArcGIS Pro, 5 map(s), activeMap = False
Loading Workbook
Validating data mappings
Calculating new asset types
Extracting source/target mappings
No association records found DynamicProtectiveDevice key SupportStructureDynamicProtDev
No association records found Streetlight key SupportStructureStreetlights
No association records found Transformer key SupportStructureTransformers
