When using Create label classes from symbology in ArcGIS Pro, the existing label configuration should be preserved, with only the text colour taken from the symbology class.
At present, even after carefully configuring labeling (e.g. font type, font size, halo, offsets, callouts, scale ranges, repeat labels, remove duplicate labels, placement rules), creating label classes from symbology resets labels back to defaults (e.g. Tahoma 10, default placement and scales). This requires all label properties to be reconfigured for every class.
Requested behaviour
Allow users to:
- Configure labeling once
- Then create label classes from symbology where:
- The symbology colour is applied as the label text colour
- All other label properties remain exactly as configured, including:
- font type and size (e.g. Arial 8 pt)
- halo colour and width
- offsets and placement
- callouts
- repeat / remove duplicate labels
- minimum and maximum scale ranges (this is already possible as a tickbox in the create label classes from symbology dialog)
Creating label classes from symbology should not reset label symbols, placement, or scale settings, but should only introduce colour-based classes.
Why this matters
Label configuration is often more time‑consuming than symbology. Resetting fonts, halos, placement, and scale ranges each time label classes are generated significantly slows down cartographic and production workflows, particularly where layers are frequently regenerated.
