Make a way to "poke" at each geocoder role so, that we can use field mappings to map the geocoder out. So, that when a new geocoder is scripted it doesn't need to have this long string.
Hi @JacobTrimmer1, thank you for submitting an idea. I'm not entirely clear if I'm fully understanding the request, it seems you would like a way to use a FieldMappings—ArcGIS Pro | Documentation object as input to the in_address_fields parameter of the Geocode Addresses (Geocoding)—ArcGIS Pro | Documentation tool, is that right?
To help clarify, could you provide some additional details? Feel free to follow this template for your response (if it helps to break it down):Context:Currently...
Problem:The problem is...
Impact:As a result...
Solution:I suggest...
Thanks again!
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
