In Experience Builder there's the possibility to set up a custom printing tool with our own templates and configuration.
The process is relative simple and I was wondering if it would be possible to do it in Map Viewer too. Maybe there's not much room to edit and program in Map Viewer, but the option to add our own edited templates would be a great addition (not that the default templates are wrong, but it's great to have more options to customize our organization!)
In ArcGIS Server (vs. an Enterprise portal) you can do this directly with the Print Utility.
@JavierML
If you are running on a newer version of ArcGIS Enterprise, then you should see an option to browse and pick a template (as a portal item) from your portal. You can author a .pagx file from ArcGIS Pro and use the portal home page to upload a .pagx file as a portal item to be used with the print widget.
pls let me know if I misunderstood what you asked for.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
