@TBannister Since indicator 1 and 2 are coming from the same layer, Is it possible to filter the data so you can get the sum of Indicator 1 and Indicator 2 in one expression using an OR filter? If you can, you may be able to use the reference option to pull in the 2nd layer into the same indicator and filter that to get the sum of Indicator 3, then using advanced formatting, sum the datapoint and reference to get the sum of all three.
This may only work if your or filter doesn't return any overlapping data...
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
