Hi, it would be great if there was the ability to set filter default values within the Field Maps designer.
Currently you can set which attributes a user can use to filter the layer in Field Maps, but these can't be pre-set to defaults that the user could then change if wanted.
E.g. It would be great to be able to set a filter to only show 'current' records when the field map was first opened, with users being able to turn this filter off if they wanted to. (like you can do in the filter widget in Experience builder)
The only work around I know of to this currently is to set up several views of the data with filters set on these views e.g. setting up a 'current' view and a separate 'historic' view. But this means users then have to switch between these separate view layers in the app. Which isn't particularly user friendly.
Many thanks
