I am using Portal 11.3 and have a couple of feature classes with lots of fields and customised visibility and calculated fields. It is still in development and in an ideal world I would have the final schema in my feature class before publishing. However, I get asked to add additional fields sometimes with domains and when I overwrite the service I lose my customisations.
I use AGOL assistant to backup my json and try and re-apply but if the schema and domain values have changed it does not always work.
If I need to make schema changes what is the best way to keep my local geodatabase feature class in sync with my feature class without losing customisations?
Thanks in advance
