@ynpark The Error Inspector pane primarily allows quick updates to error status:
Doesn't look like editing of fields is enabled.
REF: Configure the Error Inspector pane
Hello, for Reviewer attribute rule results, you cannot edit or delete results directly from the Error Inspector pane. If you want to delete visual review results you could disable visual review for the TransportationGroundCurves FC, this will delete all visual review associated results from the error tables, and you can re-enable visual review after.
For Reviewer attribute rules you can save the configuration of a rule as an export .csv file before deleting the rule, this will allow you to delete the rule and all errors associated with it before you can bring back the configuration as an import .csv file.
As a separate option you can also use the Delete Rows geoprocessing tool to delete errors directly from the attribute rule error tables.
Can you provide more context behind the need to edit or delete errors? Thank you.
It is worth to mention that for the deletion of reviewer results, we recommend exporting the rule configuration, delete the rule that was exported to a .csv and then re-import the attribute rule. This is ensuring the validation status field in the feature is in-sync. Once the rules are removed the validation status will be set to "No calculation required, no validation required, no error".
