Is there a documented best practice for getting PDFs to be used as an offline Basemap in Field Maps 26.1 & iOS?
For reference, I have Enterprise 11.1 and 11.5 environments. I can view the PDF's as items in Field Maps just fine, and I can see where I am on the PDF.
If I take the PDF, and use the Files App on my iPad, I can manually copy the PDF to the Basemaps folder. When I look at a live/online map, I can switch Basemaps and pick this PDF that I just copied.
However, in an Offline area, I cannot switch to this PDF. I get an error "Basemap Unavailable: The Spatial reference isn't compatible with this map".
Does the Projection that was used when creating the PDF need to match data in the Web Map?
