I'm working on creating a Survey123 Connect form with one of the multiple selection questions being "Equipment Used" which consists of the options: handline, truck, broadjet, UTV, or backpack. I would like for a follow up question "Truck #" and "UTV #" to appear whenever Truck or UTV are selected. However, the issue I am running into is that whenever you select another Equipment Used option, the follow up question no longer appears. For example: if you select "Handline" and "Truck" then "Truck #" does not appear. Same goes for if you select "Truck" and "UTV" neither "Truck #" or "UTV #" follow up questions appear. There could be any variation/combination of equipment used.
