When upgrading from 4.34.x to 5.0.5/5.0.6, typescript complains about the types for the on event listeners for DrawAction.
To recreate, just setup this example from the docs in a typescript project.
function enableCreatePolygon(draw, view) {
let action = draw.create("polygon");
// PolygonDrawAction.vertex-add
// Fires when user clicks, or presses the "F" key.
// Can also be triggered when the "R" key is pressed to redo.
action.on("vertex-add", function (evt) { // <- ERROR: Argument of type '"vertex-add"' is not assignable to parameter of type 'never'.ts
createPolygonGraphic(evt.vertices);
// PolygonDrawAction.vertex-remove
// Fires when the "Z" key is pressed to undo the last added vertex
action.on("vertex-remove", function (evt) { // <- ERROR: Argument of type '"vertex-remove"' is not assignable to parameter of type 'never'.ts
// Add a graphic representing the completed polygon
// when user double-clicks on the view or presses the "Enter" key
action.on("draw-complete", function (evt) { // <- ERROR: Argument of type '"vertex-add"' is not assignable to parameter of type 'never'.ts
function createPolygonGraphic(vertices){
view.graphics.removeAll();
let polygon = {
type: "polygon", // autocasts as Polygon
rings: vertices,
spatialReference: view.spatialReference
let graphic = new Graphic({
geometry: polygon,
symbol: {
type: "simple-fill", // autocasts as SimpleFillSymbol
color: "purple",
style: "solid",
outline: { // autocasts as SimpleLineSymbol
color: "white",
width: 1
view.graphics.add(graphic);
There is a post on something similar, but our lib is already ES2024.
https://community.esri.com/t5/arcgis-javascript-maps-sdk-questions/typescript-event-inference-no-longer-working/m-p/1686849#M88198
Our version of Typescript is latest 5.9.3.
Other "on" events we have in the project (e.g. mapView.on) work as expected.
If you "cast" to a specific DrawAction, it picks the eventTypes up correctly:
const action = draw.create(mode, { mode: 'freehand' }) as SegmentDrawAction;
action.on('draw-complete', drawCompletedHandler); // all fine now
