Karen,The interpolation tools in Spatial Analyst are really unsuited for anything but the most preliminary assessment. You really should start to delve into Geostatistical Analyst for anything requiring "scientific" or academic grounding, as Geostatistical Analyst offers far more and better tools, including cross validation and exploratory data analysis. These tools in Geostatistical Analyst will help you in finding out what might be "wrong" with your dataset, and what needs to be done to make the dataset suitable for interpolation (if at all possible!). Common issues I often see:- To small dataset (like trying to interpolate 7 points or so)- Non-continuous dataset / phenomenon measured, which violates the basic principal of continuity underlying the whole "interpolation" concept. Sometimes, you really shouldn't be interpolating data, but using other (statistical) methods to process your data, like using a program like SPSS or R. Quite often, people cling to the idea of "I must interpolate this data!", while their data may in fact be unsuitable...- Non-normal distributed data. Data may need to be transformed, e.g. by taking the log.Geostatistical Analyst, with its Exploratory Data Analysis tools, will help you in finding out if your dataset is suitable for interpolation, and help with possible transformation or other settings needing to be made before or during interpolation.You may find the document by Gregg Babish, that I linked in the below thread post, useful as a basis for better understanding interpolation techniques:http://forums.arcgis.com/threads/95588-Simple-Kriging-question-please-help!!?p=339687&viewfull=1#post339687
Hi mboeringa2010,Thank you so much for such a comprehensive reply and the links for further reading. The problem I have is that this is part of an acacademic exercise so I would assume that the given I have been asked to run the Spline operation, the data are set up for this. I was given specific instruction to set the environment etc. So surely the lecturers would not be setting me something that is unsuitable or inappropriate? Indeed I hope not, I am trying to learn about GIS not be put off it altogether :-O.
I have read another forum thread where people appear to have been having similar problems with running the Spline with boundaries operation. One of the replies suggested that java script could be causing a problem. I am not that confident on playing around with the set-up of my laptop but I would feelOK following step by step instructions.
Once again, I really appreciate your logical and helpful response. I will look at the link you suggest and will see if it sheds any light. Many thanks, Karen
