Do any of you experience when you tried to exit ArcGIS Pro. Its takes a bit longer to exit when you work with a few or lots of DWG files ?
Is this a known bug or is it takes some time for the ArcGIS Pro to process remove each DWG entries at a time ?
If the data are all locally stored on your computer, it shouldn't.
There are no bugs listed on the public facing support site.
I have not heard of this personally but one thing to try is do a "save as" for a new *.aprx file. Close ArcGIS Pro. Load the new *.aprx. Close ArcGIS Pro. Does the latency still exist?
On network but all of my DWG files are within the same folder that I bring them to Pro.
All right. Let me test it and let you know
networks complicate any solution, but if Robert's "save-as" suggestion doesn't pan out, try moving your cad data to your local machine, then compare
Yeah I save as a new project file with DWG_Georeference and test it with a few DWG files... I removed them and then exit . It exited very quickly....
I had a different project with a different name. I looked at the importlog...and it has 173 of them... Would that be the reason for taking a while to exit ? Just thought about that.
Could be. You can test by removing 1/2 of the files, save as, and exit the app. What's the timing? If zippy fast, then maybe there's a magic number where ArcGIS Pro may have an issue?
