Hi folks,
I am looking for python script that extract all domains where
code <> description
from SDE(oracle) database. any sample code that I could reuse is greatly appreciated.
Ram
NOTE: In your version, if a domain has multiple non-matching values, it is added multiple times.
You can also do this in a dictionary comprehension:
def bad_domain(dataset: str): from arcpy.da import ListDomains return { d.name: d for d in ListDomains(dataset) if d.domainType == 'CodedValue' and not all( value_key == value_description for value_key, value_description in d.codedValues.items() ) }
I usually like to unroll these types of filters into multiple functions so it's clear exactly what checks are being made:
from typing import Any from arcpy.da import Domain def is_bad_values(val: dict[Any, str]): any(k != v for k, v in val.items()) def is_bad_domain(d: Domain): return d.domainType == 'CodedValue' and is_bad_values(d.codedValues) def bad_domains(dataset: str): from arcpy.da import ListDomains return {d.name: d for d in ListDomains(dataset) if is_bad_domain(d)}
If you want to get REALLY re-usable, you can use a registration pattern:
from collections.abc import Callable from functools import wraps from typing import Any from arcpy.da import Domain type DomainValidator = Callable[[Domain], bool] Validators: list[DomainValidator] = [] VALID = True INVALID = False def register_validator(func: DomainValidator): Validators.append(func) @wraps def _wrapper(*args: Any, **kwargs: Any): return func(*args, **kwargs) return _wrapper @register_validator def domain_value_check(d: Domain): if d.domainType == 'CodedValue' : if any(k != v for k, v in d.codedValues.items()): return INVALID return VALID @register_validator def domain_range_check(d: Domain): if d.domainType == 'Range': min, max = d.range if not isinstance(min, (int, float)): return INVALID if not isinstance(max, (int, float)): return INVALID if min < 0 or max > 100: return INVALID return VALID def bad_domains(dataset: str, validators: list[DomainValidator]=Validators): from arcpy.da import ListDomains return { d.name: d for d in ListDomains(dataset) if any(validator(d) is INVALID for validator in validators) }
Now you can just add and remove validations as you please.
Something like this
egdb = r"GDB.sde" badDomains = [] for dom in arcpy.da.ListDomains(egdb): if dom.domainType == "Range": continue for key in dom.codedValues: if key!= dom.codedValues[key]: badDomains.append(dom.name) print("done") print(badDomains)
The List Domains function is what you're looking for, this will work on any EGDB. The sample code on that page should get you started.
