I have a list of feature class names I want to feed into a script, and one of the things I need the script to do is determine whether each feature class is held within a feature dataset (as then the script will treat the FC differently).
Using Describe I can identify feature classes and feature datasets, however I cannot determine whether a FC is within a FD. I can list children of a FD, but not parent of FC.
Is there another way I can easily determine whether a specified FC is held in a FD?
The list of FCs is output from a third-party table, so doesn't reference feature datasets. The FCs are contained in a database that has many feature datasets and hundreds of feature classes. While I know I could Describe all the FDs in my database and compare the children to my list, I imagine this would take a long time, when my list only contains about 60 FDs and only about 15 of them are in FDs.
EDIT: If possible I would like to determine the name of the Feature Dataset, not just if there is one. Data is in a SDE Geodatabase (SQL Server)
Mike.
Message was edited by: Mike Louwrens
