When editing a web map in Map Viewer, using the Fields button on the right to edit a layer, every time I delete a field the window closes. It would be nice if 1. I could delete multiple fields at once and 2. The window would remain open.
Hello @HollyWilson331 , it doesn't really answer your question, but this Blog does offer an alternative way to bulk delete Fields.
https://www.esri.com/arcgis-blog/products/arcgis-online/data-management/adding-deleting-fields-in-map-viewer
"Bulk deletion of fields is not supported in this workflow. If you need to delete multiple fields at once, you must go to the item details page for your layer and delete the fields via the Fields panel in the Data tab. "
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
