All, I identified the issue. The error is caused when more than one intersecting line with the main line. So when it goes to make the jump on the second line, it has an error because of the first jump. I added code to handle the error and present a warning. I found that some odd geometry can occur in certain situations. I made the fix in the 10 release of the template. I also merged the changes into the 9.3.1 version. Attached is the updated DLL, you will need to replace the old one with this one.Updated DLL 7-7-2010 - Unrelated Bug fix
I was fighting with this problem as well, I changed the jump distance to something much smaller and it started working properly. I suspect that the segment ArcGIS was trying to create was larger than the available room, due to proximity to the end of the line.
