I have a widget controller with two widgets. I would like to decrease the spacing between the widget icons. have set spacing to "0", however, the icons are still spaced considerably. Anyone experienced this issue before?
Thanks in advance,
M
The Spacing setting does not allow for negative numbers, I wonder if modifying this in the widget code would allow to reduce spacing more.
I just updgraded to 1.19. The custom setting did not help. I'll dig in and modify the widget code directly I suppose.
I should have asked if you are using AGOL, Enterprise, or Developer Edition of EB. The current version of AGOL and DE 1.19 support it, I am not sure which version of Enterprise supports this, but probably 11.5 or 12.
Thanks for the tip. I must be running an older version. I don't see the custom option:
If you change your size from Large to Custom in the drop down you may be able to play with the spacing to get it to look how you want.
