Working on a Water Distribution Utility Network Prototype. I've successfully delineated the "Water System" Tier 1 subnetwork using a "Source" subnetwork controller which is at an intake on a river. I've also been able to delineate most of our Tier 2 "Pressure Zone" subnetworks.
The question I have is, how to delineate the gravity-fed Tier 2 subnetwork (in our case named "G0"). Essentially this would seem to need to use the same subnetwork controller as was used to delineate the Water System Tier 1 tier. But as far as I can tell, a subnetwork controller can only participate in a single tier. Would I need to create a second "dummy" subnetwork controller just downstream of the source? Or is there another better way to approach this?
