I can confirm this bug with 10.0sp2. If you have a table to geocode that contains one or more null values in one of the input fields ArcMap (and geoprocessing scripts) will crash. The error appears to be intermittent/random. Eliminating the null records from the input data set is a workaround until the bug is fixed by esri. Note, applying the geocoding service patch for 10.0 sp2 does NOT fix the problem.The same input data set runs fine using 9.3.1.
