Based on the following sample:
Feature layer with popup | ArcGIS API for JavaScript
I created this:
FeatureLayer Select - JSFiddle
I don't understand how this is working -- I removed the map.on("click") event as it was always being called twice. It seems as if there is some default onClick event that is applied.
Thanks.
Glen,
having a popup for your map/feature layer is your first on click event. Once you add an on click event for your feature layer, that will be your 2nd.
I hope this is what you are asking
Tim
Robert -- that did it, thanks!
Once the user zooms to a selected feature, I'll be adding new features to the map (another feature layer) within that selected area of interest. The user will then select features from new layer. I will add an event to handle the selection (e.g. on drawend). I don't want the popup click event still active.
Sure there is a setInfoWindowOnClick method you can set to false.
Map | API Reference | ArcGIS API for JavaScript | setInfoWindowOnClick
I think the best question would be, what do you want to achieve?
Thanks Tim. Is there any way to remove the popup click event?
