I am using v4.33 of the ArcGIS Maps SDK for JavaScript.
I am disabling all the zoom-to animation for performance purposes. I notice that the goToOverride on the Locate map component doesn't work. The overriding function looks like below
export function noAnimateGoTo (view, goToParams) {
goToParams.options = {
animate: false
return view.goTo(goToParams.target, goToParams.options);
};And I loaded the locate component like this
export function createLocateWidget (arcgisMap) {
let widget = document.createElement('arcgis-locate');
widget.position = 'top-left';
widget.goToOverride = noAnimateGoTo;
arcgisMap.appendChild(widget);
I use the same goToOverride method on the Home and Search widgets and both work.
I check with v4.34 of the JS library, and it's Locate component have the same goToOverride problem.
Did I make a mistake with override? Or is there a possible bug with Locate map component?
