Is anybody else having issues with generating reports in Survey123 today?
We get the below failure on all our attempts at reports from various feature services and surveys.
Yes I also got this error overnight with no changes to my survey, services, or report template. I went through and removed all the layers it said had problems drawing (which were not critical for my report luckily) and it succeeded again.
I attempted to open a support ticket about this but haven't heard back from support.
Wasn't there a S123 update early last week or the week before? I have 2x surveys that use Power automate to generate and email reports automatically. Something happened with the webhook on one of the surveys and I had to set up a new one to fix report generation. On the other survey, some submissions are triggering the webhook and others are not, but ALL reports are failing to generate.
We experienced this same failure mode, Power Automate 'Create Report' action fails with the following error. *This was also observed directly from the Survey123 website when attempting to manually create a report.
Cross-posting here, for those that are also having Power Automate issues after the most recent update:
Re: Survey123 Connection to Power Automate Issues - Esri Community
An update from our side.....it appears that the latest S123 update has meant that layers with visibility turned off in the map used for the report cause the report generation to fail. Once these 'invisible' layers were removed from the map, the report succeeded.
Hi everyone,
Thank you for the feedback. We've identified an issue that if there is any invisible layer in the web map, printing a report using the web app will trigger the error "The layer <layerName> did not draw completely". This was introduced in the Survey123 November 2025 update on 11/13.
We have applied a fix to the Survey123 website earlier today. Please let us know if you still encounter this error.
