I would like to suggest the ability to toggle layers on and off in Experience Builder web designer. This may help address some accessibility concerns i.e. difficulty discerning the difference between features on a map for someone who is colorblind.
I need my users to see the symbol, not just the name of the layer. The workaround I've come up with in the meantime is to use a filter widget. Unfortunately it has to be configured backwards in order to work. When the user turns it "on" the layers disappear.
@SarahRijneke, could you elaborate on this idea further? I do not get it.
We support layer visibility control in the DS:
If you're referrring to the runtime, the Map widget > layer tool, or the Map Layers widget provides you the ability to toggle layers on or off:
You can even enable the layer batch options
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
