I am working with a colleague using COGO reader on a legal description and are running into an issue where the reader isn't reading one of the descriptions for a curve properly (see text boxed in white in screenshot). We tried editing the text to try to guide the reader to adjust how it was reading but were unsuccessful in getting it to read properly. Would love any advice on this and wanted to share as feedback on COGO reader.
What version of Pro are you using COGO reader with?
I've had this happen to me as well, and no amount of tinkering would get it to read. ESRI seriously needs to release some guidance on the format that the COGO reader expects for the different measurement types.
I'm on 3.5.4
Yes, a lot of times I can figure out the text formatting to read correctly, but that is rarely faster than just using the Traverse tool and entering things manually.
Same! It's handy when it works but at least half the time for me it doesn't work immediately.
@LECarver_JC Can you please provide the legal description?
@Rafael_Bombacini Yes, here is the legal description:
TRACT 1:ALL OF LOT 1, "ONE PERSHING SQUARE", A SUBDIVISION OF LAND IN KANSAS CITY, JACKSONCOUNTY, MISSOURI, EXCEPT THAT PART LYING BELOW ELEVATION 74.47 KANSAS CITY, MISSOURIVERTICAL DATUM, AND BOUNDED BY THE FOLLOWING BEARINGS, DISTANCES AND CURVES:BEGINNING AT THE SOUTHEAST CORNER OF SAID LOT 1; THENCE NORTH 03 DEGREES 29 MINUTES54 SECONDS EAST ALONG THE EAST LINE OF SAID LOT 1, A DISTANCE OF 49.93 FEET; THENCESOUTH 65 DEGREES 54 MINUTES 29 SECONDS WEST, A DISTANCE OF 73.21 FEET; THENCE SOUTH 71DEGREES 52 MINUTES 44 SECONDS WEST, A DISTANCE OF 113.07 FEET TO THE WEST LINE OF SAIDLOT 1, SAID WEST LINE ALSO BEING THE EAST RIGHT-OF-WAY LINE OF MAIN STREET, AS NOWESTABLISHED; THENCE SOUTH 03 DEGREES 29 MINUTES 54 SECONDS WEST ALONG SAID LINE, ADISTANCE OF 60.85 FEET TO THE SOUTHWEST CORNER OF SAID LOT 1; THENCE NORTHEASTERLYALONG THE SOUTH LINE OF SAID LOT 1 ALONG A CURVE TO THE RIGHT, HAVING AN INITIALTANGENT BEARING OF NORTH 40 DEGREES 29 MINUTES 06 SECONDS EAST, A RADIUS OF 110.04FEET, A CENTRAL ANGLE OF 31 DEGREES 21 MINUTES 20 SECONDS, AN ARC DISTANCE OF 60.22 FEET;THENCE CONTINUING ALONG THE SOUTH LINE OF SAID LOT 1 NORTH 71 DEGREES 50 MINUTES 31SECONDS EAST, A DISTANCE OF 92.65 FEET; THENCE CONTINUING ALONG THE SOUTH LINE OF SAIDLOT 1 ALONG A CURVE TO THE LEFT, BEING TANGENT TO THE LAST DESCRIBED COURSE, HAVING ARADIUS OF 511.30 FEET, A CENTRAL ANGLE OF 04 DEGREES 29 MINUTES 16 SECONDS, AN ARCDISTANCE OF 40.05 FEET TO THE POINT OF BEGINNING.
@LECarver_JC Can you send a screenshot of the legal document?
@Rafael_Bombacini Yes, here it is.
@LECarver_JC Thank you for sending the legal description. As you know, legal descriptions can be written in several ways. In this deed, the first curve (non-tangent curve) is defined using the bearing of the tangent to the curve, whereas it’s more commonly given as a chord or radial bearing. We can accommodate this format and update our logic. If you encounter other variations we should support, please let us know so we can better serve you and your cases.
