I find that when I zoom in from one slide to the next, with a regular web map it actually does the zoom motion in user mode, but when I try to do it with an express map, it doesn't. Is this just the way it works, or am I experiencing an anomaly?
@AmyNewsam -- I apologize, this was my mistake. 😕 Express maps do not yet support map choreography in this way. This is something we are considering for the future, but it is not available at this time.
@AmyNewsam - Make sure that you duplicate the slide with the express map and then configure the next view with that duplicated slide.
If you make a new express map, the map won't smoothly transition between views.
Please let us know if this helps resolve the issue you are seeing.
Yes, I duplicate the slide. But the issue isn’t the slide but the way the slides transition from one to the next. In a sidecar using a web map, you can actually see the movement from one view to the next, like you’re watching the camera pan and zoom, but in my sidecar using an express map, it just jumps to the next slide without any transition movement.
