Turns out it wasn't an ArcGIS Server issue, but a setting that needed to be changed in our VM software after increasing the amount of RAM.
I'm having similar memory problems with a new install of Server 10.1 - any idea what VM setting you changed?
And same here: no VM, memory at 90% capacity, and often CPU usage peaking towards 100%. Stopping services does not make a difference.RJ
Just a tip, which may or may not be useful in this situation:If you goto Task Manager, and under VIEW > Select Columns. Turn on "Command Line".In the processes tab you can then see in for each ArcSOC.exe process which service it is running.The name will be found at DService = "...."This might be useful in helping to identify which services require more memory than others and planning deployment.
I'm going to wake this thread up.Anybody know what the VM setting to change is?
Oh, and I noticed that stopping the ArcGIS Server and ArcGIS Web Applications Manager brings down memory use from 9Gb out of 10 to 1.6-ish. Turning them back on doesn't bring them right back up, but CPU is close to 100% and memory is creeping up pretty fast...RJ
Help! We're experiencing the same memory issue with zillions of SOC instances and huge Java processes. It's rendered our server unusable. It looks like no one on this thread has found a solution, but I'm posting just in case.Thanks!
We have something similar - did we get a response to this?
Fraser
Hi Eric
We have exactly the same issue after an upgrade from ArcGIS Server 10.2 to ArcGIS 10.3 2 weeks ago.
Same environment - VMWare and Windows Server 2008 R2.
Did you ever find a solution to this?
Is VMware an issue would Hyper Visor be a better choice of virtualisation?
Susan
I am more a fan of Hyper V. Did you upgrade in place…using the same VMs? Can you detail your old environment and the new one, tell us what the symptoms are….
